JimK-NY's avatar
JimK-NY
Explorer II
Apr 16, 2019
LED Dome Lights
I would like recommendations on LED dome light fixtures. The light from the ones I bought are not even. In addition they cast annoying yellow lines and blotches. Thanks
  • Well I installed one over the dining table, we play, eat, read there. Also, to replace the ceiling lights in the rig I just bought new bulbs. They fit into the same sockets.
  • Artum Snowbird wrote:
    We got these ones. We really like them.
    Mictuning
    I guess you do not care about this issue because here are some reviews from the link you provided:
    "The only problem is that the dumpling is so heavy on the lens the light comes out as shadowed and uneven."
    "Very cheap but they cast an unusual light, you see yellow and blue streaks on the walls when you turn them on."
  • Here are some other comments that explain the issue:
    "These are very bright and easy to install but there is definitely a cross-hatched pattern of lighter (whiter) and darker (yellowish) light emitted from these fixtures. It is much more evident when illuminating a solid white object than anything else. If those who haven't noticed it would hold up a sheet of white paper anywhere the light shines I'd almost guarantee they'd see it clearly. We have several white surfaces in our camper where I installed three of these and the projected patterns was very annoying. The yellowish bands are about the same color as white plastic after it has aged, so not only is the pattern itself distracting, whatever it's shining on looked old and dreary too. So I was in a quandary trying to decide if the much brighter output, lower power consumption and heat was worth enduring, and hopefully getting accustomed to the banding. .."
    "These are terrible, they make everything in the fifth wheel yellow and white blotches. I finally can't stand it anymore and I am buying nine new fixtures to change them out."
    I have found the same sorts of negative comments on reviews of many LED dome light fixtures. I am looking for fixtures that do not have this issue.
  • MDKMDK wrote:
    Could you be a little more vague? :h
    I am not sure what is difficult to understand. The lights cast yellow lines and splotches. Mine are similar to Kohree brand. Read the reviews on Amazon or elsewhere and you will encounter the same negative comments.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 06, 2025
