Just installed a LED strip light in bathroom and works fine off of 12v. Cranked up generator and light flickers. Only this new one, have about 10 other bulbs that work fine. This new strip is 2 spe...
The Magnetek has two outputs. One goes directly to loads and is completely unfiltered with lots of AC ripple. The other side charges the battery, so that the battery itself acts as a large filter. I agree the best solution might be to retire the Magnetek, but you can also try moving the circuit that feeds the light over to the filtered side. I believe my old Magnetek had two fuses on the right that were on the filtered output.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
