GordonThree wrote:
I always curse you guys running hid or led in a reflector style headlights. Very unfriendly move towards your fellow drivers. I don't flash, not worth getting in a headlight pissing contest.
Check a scrapper for the factory projection headlight assembly if you want to join the hid / led club. Alternately retrofit projector lenses can be had for most trucks.
Actually it is not HIDs or LEDs in THOSE folks lights..
They are the cheapo incadescent bulbs which are TINTED BLUE to make their lights LOOK LIKE HIDs!
Those blue tinted bulbs are not DOT approved for ON ROAD USE and often do not have the filament in the correct place to focus the light correctly..
The blue tint adds to the SCATTER of the light making it even worse for the motorist in front or approaching a vehicle with those junk blue tinted cheapo wannabe be "HIDs"..
The current crop of LED retrofit lights are hit or miss on getting proper focus AND good ones that do work are not cheap.
Not to mention ALL of those LED conversions are at 6000K color temp, I would consider LEDs IF they made them at a more reasonable 4000K-4500K (that color temp is the range of HIDs not 6000K).
OP should check the voltage at the light bulbs, typically the light ga wiring the vehicle manufacturers use will end up dropping nearly 2V by the time it gets to the bulbs (I HAVE measured this with my vehicles)!
The fix is to add in a headlight relay kit.. A relay kit uses a heavy ga wire that goes directly to the battery.. The result will be about 20% or better brighter lights..
I would skip the LED conversions at this time, they are a "work in progress" and still have a lot of short comings at this time with proper focus, unreliable thermal (heat) management (IE a fan on the back of the light) and electronic "driver" circuits which CAN emit enough RFI that your TPMS and even ABS systems can be affected.
Your money and your time, do with as you wish..
