AidenJ's avatar
AidenJ
LED problems
Recently bought 4 new LED bulbs to replace the incandecent ones for interior lighting in a truck camper. They are the wedge type 921 bulbs. The problem is they shut down after about 15-20 minutes. They will come back on after a short time, but then go back off. All 4 do the same and it doesn't matter what fixture I put them in. Any ideas?
  • Some of the thermal limit systems are designed for 12.7 volts not 13.7
    Do your test again. But exact time the shutdowns
    Unplug
    Wait at least 4 hours or overnight
    Retest
    Do the bulbs stay lit longer when unplugged?
    Then you ID'd yes/no as a thermal issue.
  • 2oldman wrote:
    Check voltage.
    The bulbs you got might not be the right ones for those fixtures.
    Hopefully the old bulbs have a number on them.....and you can look up the spec's and see if they really are 12 V or something higher.
    Those fixtures may have a "balast" that increases the voltage for a halogen bulb, just as an example.
    When they go OFF, are they HOT to the touch ?
  • All four shutting off at the same time? If so the problem is a power issue, not a lamp issue.
  • bad bulbs, possible improper solder job. Return them to supplier
