2DHoop's avatar
2DHoop
Explorer II
Sep 13, 2017
LED Tailight Weak Flashing Issue - *Solved*
***not sure if "taillight" or "tail light" is correct" as I've seen both...
Item in question is the Bargman series 84 light set with the 47-84-420 LED part #.
Just one side has the issue of an intermittent weak flash. Test light flashes correctly so I believe this indicates good signal from the wiring
If I apply the test light to the connection, then the LED assumes full strength again. I'm guessing this is an issue with he LED light but before I apply a fix action, I wanted to determine from the experts if adding a permanent small load (as the test light does) would be smart or just try a repacement LED light for about $30?
Thank you
*Replaced the fixture with above mentioned part # and it works as it should. Problem was a malfunctioning LED fixture and not the wiring. Thanks for the help from everyone!
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
