My granddesign has regular taillights, if I Change them to led is it just a plug and play or did I need to do some thing else thinking of going with Bragman tail lights
On my RV.. I just swapped LED's for the burn-out-a-matics the factory put in Have not had a problem since. (12 years)
Some if you do that you will get fast flashing, when that happens you need to add a ballast resistor (or load resistor) so you bring the current back up to what the burn-out-a-matics used.
Suggestion: Try it and see what happens.
