Busdriver
Sep 04, 2017Explorer II
Led taillights
My granddesign has regular taillights, if I Change them to led is it just a plug and play or did I need to do some thing else thinking of going with Bragman tail lights
valhalla360 wrote:
Better reasons:
- They tend to be much brighter than you standard incandescent bulbs.
- And the big one: Incandescent bulbs take about 0.5 seconds to illuminate once power is applied to the circuit (It takes the filament that long to heat up until it creates visible light). LED takes about 1/10th as long to start producing light. That's almost an extra 1/2 second for following vehicles to react to your brake lights. That can be the difference in an accident or not (or between a serious crash and a fender bender).
joebedford wrote:
Putting LEDs on a trailer shouldn't change the flash rate.
SidecarFlip wrote:
Whatever.
SaltiDawg wrote:SidecarFlip wrote:
LED's draw much less power than a conventional filament bulb. While the power loss in tiny, your alternator only puts out so much power.
Reduced load demand is not the same thing as reduced parasitic loss.
SidecarFlip wrote:Bumpyroad wrote:
why bother?
bumpy
Because I can for one and because the less of an amp load on the electrical system, the less parasitic power loss there is and three, I like them.
