CFBLACKTRIKE's avatar
CFBLACKTRIKE
Level-Up leveling jacks
I have a 2015 Voltage toyhauler. When I RETRACT the jacks the system cycles bout 8-10 times ,, on-off before the the jacks are fully retracted. All other functions of the Auto-Level system work fine. This only occurs when I "Retract " . Any body else experience such a problem ? Any ideas what component to look at ?
  • Sounds like the orig. 40a breaker is the problem. You can search here for a lot of posts. Solve by replacing the breaker with an 80a. Think Lippert has a bulletin on their website.
  • Kinda thinkin the same way ,,, ain't sure just what amp the OEM breaker is. Wasn't too sure just much bigger to go ,,, Thank Ya Much
  • I ended up installing a 90 amp breaker to replace the 50 installed from the factory. I also increased the wire size with the breaker.
