dougrainer
May 28, 2017Nomad
1970nds wrote:
Yes, Hydrolic. I will check to see how many lines are running to each jack. It does not have external springs on them.
I am sure that it was completely retracted and I noticed it about 2 weeks ago and retracted them. Went back yesterday and is is down about 3 inches again.
If a solenoid is leaking, wouldn't it also drop when on the jacks? Meaning when leveled it would also retract to some degree?
Yes, if the solenoid was leaking. But, I doubt the jack is coming down. I will bet it is NOT fully retracted, which can mean you have overfilled the Tank reservoir. The excess fluid causes the jack to not fully retract because it has no where to go. Because the tank is overfull the Jack down light will also go OFF. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
