timberlake's avatar
timberlake
Leveling Jacks won't deploy
I have a 2005 Itasca Suncruiser 35 the slide outs function fine but after I returned from my last trip I parked it next to the house and went to level it but when I pushed the buttons the motor sounded normal but they did not drop- again the slideouts are working fine- any info would be appreciated. thanks Bill
  • enblethen wrote:
    Have you checked to insure control unit has power? Sounds like no power to operate solenoids.
    Make and model of jacks.
    Not sure what control panel you are referring to the one on the dash? That has power if not that which one? I don't have a manual for it so I don't know the make and model I'll have to figure out by searching I guess...thank you
  • Check to ensure the switch for the parking brake is showing the brake is on.
    If the light isnt on, jacks wont work.
    next would be fluid level.
  • Have you checked to insure control unit has power? Sounds like no power to operate solenoids.
Having RV issues? Connect with others who have been in your shoes.24,247 PostsLatest Activity: May 14, 2025
