time2roll wrote:
I want to see confirmation that solar production will increase dramatically.
You'll hear from me on that, but I'm assured by both the mfrs and an RVing couple (mentioned on here many times) that they do charge at a rapid rate, and can accept crazy amounts of amps.
They charge in 'bulk' at a constant voltage, around 14.4, or so, the whole time. No slow rising from their discharge voltage as with FLAs. Since Lis have no "discharge voltage", the solar should be cranking at a steady high voltage the entire time.
I'm psyched to get going on this but it could be another few weeks. Being real careful as it's a big investment, and if done right, will be the last batteries I ever need. I don't want to think about it being done wrong! :(
Searching_Ut wrote:
With lithium, you often see them using 70 percent, 60 percent or even less, which makes comparisons to other batteries that have used the 80 percent standard an apples to oranges type of thing.
Which is another reason I should probably get more capacity than I think will be sufficient. I'm putting an AH meter on my batteries next week. That will tell me what I should do.
