grizzzman wrote:
2oldman wrote:
grizzzman wrote:
one battery will charge/discharge sooner then (sic) the others.
Which explains why the '48v' 4-pack charger has 4 separate charging wires.
Ok..... so do the same 4 wires help 4 12 volt batteries discharge equally at 48 volts?
Indirectly yes. I believe the idea is to get them charged to the exact same voltage after each cycle. With the 48 volt solar doing most of the charging in series is when the individual 12v batteries can become unbalanced to each other. I would want a voltmeter on each battery if this was the set up.
