No temp compensation I'm aware of. My AGMs showed a full charge usually around noon.
MrWizard wrote:
i think he said the lithium needs 58v for a fast charge
It needs 58.4 as a bulk charge. That's all it says. Solar is running full bore now as the sun is almost directly overhead.
When I set the Absorb voltage on the Outback, that tells the controller to start charging at Bulk (whatever voltage it chooses) until the battery voltage reaches the Absorb point. That's what it does, that's what the manual says it does, but that's not what I want. I want the voltage to rise to the 58.4, then taper off to Absorb.
The only way I can see to workaround this is to set the Absorb to 58.4 and the Float to 55.2 (the absorb voltage.)
