MrWizard wrote:
Yes but it was four hours at very little amps
And only a few minutes 'by what he said' for a decent 30 amp charge rate
He could only have been replacing a couple of amp hrs
Not a real comparison to the amount of power use and charging for the OP or for many of us
For the OP 17 amps at 58 volts is equal 68 amps at 14v, one hour of that charging means a pretty good overnight use, over 900 watt hours
NG8S must be at near 100 percent charge on his lithium bank
You need to go back and study the graph. I put 192 Ah into the battery in that charge cycle.
4 hours starting at 30 amps and increasing to 64 amps.
