Well two of them are above 13v, the other at 12.88v and I'm sitting here wondering what the heck did I just do. I'm reading Lifelines manual and see I need a better charger than the good ol 2/12/70. I'm pretty sure the TS-MPPT-60 can handle a conditioning charge but not a deep discharge recovery. That is of course when it is set up and the sun shines, neither has been often lately.
Tomorrow is sunny so I will set up the system and hit the lower voltage one first. I want to see how each does alone before hooking them together. One is lower in voltage, I don't have any lugs yet and I'm not sure my system has the power needed to slap all three of them around at once.
As for the weight, any batteries were going to add weight. These are going over the axles opposite of the kitchen. That will let me put the controller in the rear compartment and have shorter runs of wire everywhere. The rear hold is accessible thru the bunk so the controller will be mounted on a board that can be lifted up to working level. Not having the batteries on the tongue will allow me to upgrade to a 50 gallon fresh water tank.
Got the solar, controller, inverter, wire and batteries. Time to work out the switching, fusing and layout. I might even get to see it all work this season.
