BFL13
Mar 05, 2018Explorer II
"another year or two out of this bank of batteries. May even jump back to only the two best batteries and run with 400AH's if needed, "
You need to be clear about AH capacity to do the 20% mentioned above. Two 6s at 400AH seems unlikely.
In the OP do you mean 17 amps draw and not "AH draw"? It is all very confusing.
11 volts at 85% SOC is crazy. Likely, your monitor entries for AH count are way wrong. Some monitors need frequent resets of the AH counter. Also the correct AH capacity of your four-6s bank in case that is wrong.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
