GordonThree
Mar 05, 2018Explorer
The Magnum BMK is a pretty advanced unit, it's not a simple ammeter.
The Magnum itself uses temperature compensated charging.
When I discharge on my bank, the Ah returned has always been more than the Ah withdrawn... This shows up as + on the Ah counter. The charger doesn't rely exclusively on the counter alone.
MS2812 maxes out at 125 amps, if you need more current you can run two in parallel, or supplement with a Meanwell or something like that.
