BFL13
Mar 06, 2018Explorer II
You only need one monitor, but do check the shunt(s) for what the monitors "see". Not sure about sharing shunts. Trimetric has a choice of 500 amp or 100 amp shunt. 500a is needed if you will be running bigger 120v items with an inverter. The size of shunt also affects the readings on the display. One decimal place voltage with the 500 and two with the 100 ISTR.
What amp size shunt is specified for the Magnum and what size for the Whizbang? If they are sharing a shunt, is it the right size for both?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
