brulaz
Mar 06, 2018Explorer
CA Traveler wrote:
The Magnum uses the traditional charging algorithm. At the end of bulk when the amps start to taper it enters absorb and the voltage stats to taper.
"Traditional" ?
I always thought that the traditional bulk/absorb charging algorithm was constant current / constant voltage ?
Which is the same as when using most power supplies, like the Meanwell: Max current until the voltage set point is reached, followed by constant voltage and declining current afterwards.
Is a tapering V during absorb that common in chargers? I know my Rogue Solar MPPT charger doesn't do it. Don't recall my Progressive Dynamics converter/charger doing it ...
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
