CA_Traveler
Oct 09, 2023Explorer III
Flooded battery charging is completely different than lithium. While a 3 stage charger can charge lithium it may not be the best for you. Lithium can take a full charge until the amps drop to 3% and then the charger should shut down, checking to see if additional charging is needed.
Maximum rate charging means less time and that can be beneficial for gen or solar based charging. Pedestal charging may not be a time factor.
Of course lithium batteries can be discharged deeper w/o issues but then that power needs to be restored. But nice to have that option.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
