StirCrazy
Oct 09, 2023Moderator
So, a couple things here. I just looked up your converter and no it's not made for Li, but it will work, kind of as you can set a single voltage. Yes, setting for 14.4 would be good for charging but if you stay plugged in for any length of time, I would want a way to disconnect the batteries, so they are not held at 14.4 for longer periods of time.
Ideally you would have a two staged converter that has the main charge at 14.4, then a float of about 13.6V or even a bit lower.
I also looked up the batteries and they say the standard charge current is 40amps per battery and a max of 100amps per battery, so you could have went with a larger unit. The only time you're going to hurt the battery by charging it is if the battery gets too hot while you're charging it. but it also works if you are under the standard, won't increase the life at all just ensure the temp build up is lower.
second (not for the original poster), I am not sure where this idea of basing the life of a LFP battery over time instead of cycles is starting to creep in from, but it only works out for a cycle life of 3650 and a full cycle every day for 10 years. It isn't really a good way to measure life as how many people fully cycle your battery every day. Also, every battery generation comes out with a different cycle life. The new cells I have on order say 4000 at the 25C standard, and if you operate between 10 and 90% instead of 0 to 100 they raise it to 6000 cycles. So instead of using 10 years to 80% let's try stick to the true definition of cycle life which is the number of cycles (defined as 100% to 0% and back to 100% ) that it will take to reduce the battery to 80% of its initial capacity. So, for instance, my new batteries are eve 304Ah cells which quite commonly will put out up to 320AH new. So, if that is what I get on a capacity test, I would expect after 4000 cycles if I used all 100% of the capacity that I would have 256AH left and still have a perfectly usable battery, just somewhat smaller. I doubt I would ever reach the cycle life of the battery in my current way of using them.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
