BFL13
Jan 11, 2021Explorer II
https://www.powerstream.com/lithium-phosphate-charge-voltage.htm
FWC's link says you get "some" charging at the low voltage. Says you don't get as much capacity. So that is contrary to the aim of getting more AH in the same space. (If I understand that right)
You also have the generator time issue, if you are not charging with many amps. Waste of gen time and gas. The 6300 is slow! Li can take high amps and means short gen times. So waste of the big bucks to buy Li and not have a high amp charger if you do gen time.
FWC might know this or somebody. The 6300 converter uses the battery as a filter to clean up the DC to run electronics as wired with its split DC fuse panel. Does an LFP batt filter ok like a lead-acid does in that role?
