3_tons
Jan 11, 2021Explorer III
FWC wrote:
At 13.6V you will get somewhere between 95 - 99% charged. The question would be what is the *actual* voltage your converter is putting out?
Either way, if you are upgrading to a lithium battery it is probably worth upgrading the charger even if it is not strictly necessary.
Thanks for providing a sentient response!!
In fact LiFePo4’s don’t require a full charge except for an occasional BMS cell-rebalancing, and of the reputable drop-ins I’ve seen, DOD’s are often rated at a full 100%...This is likely the basis of the OP’s inquiry rather than of SiO2...JMO
3 tons
