StirCrazy
Jan 12, 2021Moderator
BFL13 wrote:
Understand the "density" point. BUT--we are talking about "space" for one battery in the battery compartment. The SiO2 27 is a 27. You can run it down to a low SOC no problems so you can have more AH in the same 27 space, which is what the OP wants.
I don't know the true story about Li charging, but I suspect others will want to comment on using a 6300 converter for that. Should be interesting! :)
and the same ah in LiFeO4 is about 1/3 the size. so for a limited battery space the Li is the better choice. also a lot lighter for the same AH capacity.
Steve
