3_tons
Jan 13, 2021Explorer III
“ That means you can restore 125AH in an hour which means you have a 125 amp charger. Also that the batts get to 100 with no tapering. The Onan gen can run the 125 amp charger.”
So with SiO2, sounds like there’s no chemical soup resistance?...Not sure what you mean here but I must say that that is pretty dang impressive, outpacing even LiFePo4 !!...
Either way, for uber efficient off-grid solar harvesting (within peak harvest window), internal resistance is a factor worth considering...
3 tons
3 tons
