BFL13
Jan 14, 2021Explorer II
Lots of calculations can be made. One thing to remember is that with a 5er you can carry lots of batteries and a big portable gen to run a big amp charger, so you can take advantage of Li charging amps.
(But then I would say since you can carry all those FLAs why spend all that $ on LFP? Seems silly to me.)
With a TC, the first limit is the size of generator you can take along, if any. That can reduce the size of charging amps and whether an Li is "worth it"
And with the TC, you could have a battery space limit so LFP and SiO2 get you more AH in that small space. And then if it is a small TT so weight matters, then LFP beats SiO2, but if it is cold temps, then SiO2 beats LFP if you can carry the weight.
Each RVer has to use his brain and figure what would be best for him. Ignore the Elmer Gantry salesmen pushing the latest thing. :(
