time2roll
Nov 22, 2021Nomad
jaycocreek wrote:That seems low to me unless it is a special chemistry. Yttrium does this and will have a Y in the name.
Reading on LFP cold cut off I see Expert Power has 23F as there cut off on there batteries and I thought it was 32F?Expert Power wrote:
Question: Do these have low temperature protection. Will these work for solar power systems?
Answer:Yes, the do have low-temp cut-off (23F for charging / -13F for discharging)
Which is it or?
Generally even 32 is pushing it for most LFP as amps could be limited. I recommend making provisions to keep the battery above the 35-40 zone for best life and performance.
WINSTON WB-LYP100AHA LiFeYPO4
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
