theoldwizard1
Nov 22, 2021Explorer II
The issue is charging more than discharging. Also, whether you were in use before the temperature dropped below freezing.
If you are continuously discharging, you CAN go from above freezing to slightly below freezing (23F sounds reasonable), but do not try to recharge at the temperature.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
