time2roll
Nov 22, 2021Nomad
theoldwizard1 wrote:A good BMS will block the charging at low temperature and block discharge at an even lower temperature.
The issue is charging more than discharging. Also, whether you were in use before the temperature dropped below freezing.
If you are continuously discharging, you CAN go from above freezing to slightly below freezing (23F sounds reasonable), but do not try to recharge at the temperature.
