noteven
Nov 22, 2021Explorer III
pianotuna wrote:noteven wrote:
Some battery makers are now building self heating LiFeO4 batteries.
No they don’t use their own amp hours to heat. The batteries can deliver energy down to -20C battery temp.
They use energy from the charging source to warm the cells. Then they begin to charge.
Lithium batteries can accept charge at very high rates.
This is why a small generator or engine alternator charging is probably step one in a lithium system then do the solar spend to round out the system, especially if you camp in winter, forest, shade, or rainy lands.
I wonder how long the heater would take to warm the battery bank at -37 c?
Best possible charge rate for best cycle life is 0.2 c. A 0.5c works well, too. Yes, you can charge faster--but with a trade off in cycle life.
Battleborn batteries have a heated version--and it DOES draw from the battery to keep warm unless there is external power available.
If I were using them in a unit capable of -37C I would have them installed inside the heated envelope. If I had to let the unit freeze to ambient in storage at 25lbs each I would pick up the batteries and put them somewhere warm, partially charged, not needing any fussing with in storage, until I needed them again.
If you are where it gets cold, don’t buy self heaters that use their own energy would be a n option.
A guy could also use SiO2 batteries if actual cold exposure is common in the “mission”.
