Itinerant1
Aug 11, 2019Explorer
Something to remember is that the bms (battery management system) of the dropin is the last line of protection for the battery (over/ under voltage, temperature) which should shut the batteries down protecting the cells.
Having programmable charging sources that quit charging or go to float is the first line of protection.
Correct if your are storing for longer periods of time you should store at 50% +/-, disconnecting the charging sources.
