BFL13 wrote:
time2roll wrote:
BFL13 wrote:
IMO not being any sort of expert, that looks good for charge efficiency, but IMO the tail current should be 2% as chosen by Trimetric or even less as is really the case with LFPs (AFAIK)
2% tail current seems too low. Even a few RV lights on could prevent drop to float. I would be more inclined to go 20% to 50%. No need to taper an LFP to full like lead-acid.
So how do you get it to Full as required to zero the monitor and do the supposedly once a month balancing act? How can you tell when it is really Full so it can do the balancing act if the monitor is not set to get to Full?
IAW how to make sure the monitor does not drop to Float (never mind what the charger does!--who is running this anyway?--tail wagging the dog?) too soon so the battery never does get to true Full?
Yes my bad. I am thinking tail current is % of charge capacity rather than battery capacity.
