BFL13 wrote:
So what are your chosen meter settings for end of charge 3tons?
Is the balancing time part of the set Absorb time like BB's 20 minutes or come after that?
In my case, I’ve programmed the BMV 712 meter as follows (using manual’s ‘guidelines’):
Voltage, 14.2
Discharge floor, 12%
Tail current, 5%
Holding period, 3 min
Peukert, 1.05
Charge efficiency, 99%
Current threshold, 0.10a
Not sure what you’re calling ‘absorb time’, but charging does seem to taper down a small bit (final stage?) before hitting 100% SOC (pre-cell balancing)…
3 tons
