BFL13 wrote:
time2roll wrote:
BFL13 wrote:
You need 14.x to get those ions moving better. Once there you can lower the voltage
Lower charging voltage than 14.6 needs more time so keep
Float voltage same as Bulk longer too till desired SOC is reached
I respectfully disagree.
I got that from the Solacity guy.
ya that is how a lot of the misconceptions around here got started. prople taking a sales pitch as gospel. you don't know how many stores and websites I have been to where people are giving the information for older nickel cadium batteries and saying that is for LiFePO4. they are starting to get better but for a couple years it was just horrable.
there are a couple handycaps to workaround with LFP like cold weather use and charging, but this is very easily solved by moving the batteries into a conditioned space or insulating them and useing heateres (weather there home built or come intagrated into the battery) if some one is unwilling to do the work then the batteries shouldn't be blamed but rather the person who shills them as bad because they are not willing to do the work nessasary. not saying this is you in anyway, I think you are just trying to read to much into sales papers.
