StirCrazy wrote:
time2roll wrote:
pianotuna wrote:
Stir find me an Li battery that provide 9C for 5 seconds, 4C continuous, and be charged at -40. You may find that is unobtainable.
As to size, I have room for 7 Group 31, so that is not an issue.
Why would I need 9,000 amps, or even 4,000 for that matter??
If my battery actually drops to even -20 my energy and heating systems have failed to the point I am already rolling out. I mean propane does not even vaporize at -40. I would have to assume utility power is available at these temperatures(no battery required). Temps at -40 is an expedition vehicle and preparation is far beyond virtually all RVs. No reason to proclaim this as an ordinary criteria for an RV on this forum. Better suited to an expedition vehicle forum.
https://www.globalxvehicles.com/uxv-max.html
dont want to go there, I went there and searched SiO2 and here is a quote from the first post that came up .
"With the exception of cold weather charging, the specs on these are almost identical to any other flavor of lead acid battery. They are not really comparable to lithium with regard to cycle life, energy density, recharge rate etc. There do appear to be some folks shilling these on some RV themed sited that are making some very unrealistic claims about their performance. In the end, they are just extra jellied gel-cells.
The low temperature charging 'issue' with lithium is a bit overstate and fairly easy to address if it does apply."
Steve
Thanks very much for highlighting this valuable information!!….FWIW, I’d made several attempts to gain a better understanding of SiO2’s nature, but my search efforts always failed to yield even a single independent White Paper (except for a CAN vendor’s in-house paper…), and unfortunately, this lack of independent findings may have stung (??) a poor few who’ve already taken the SiO2 plunge…I’ve never once ‘knocked’ SiO2’s for others (but doesn’t work for me…), though may now warrant a re-evaluation for some - JMHO
It’s definitely kinda sad to see Caveat Emptor raise it’s ugly head again (ugg)…
3 tons
