Captn...Awesome..I find others usage interesting and useful even though my setup is smaller..I am trying different float setting and watching the difference if any..It seems 13.4 float is working well with a 14.2 (Victron set) charge but less absorption than there pre-set..
I am running two compressor fridges 24/7 with one in freezer mode which draws more power and the other at 32 degrees along with everything off the TC on one 100ah LFP..I am only getting about 55-ish amp hours a day the way the weather is off of two 100 watt panels..
Trying to keep it in bulk mode as much as I can and why I asked this question to get the most power when the sun is out and overnight the batteries have enough juice for anything needed..
Thanks..
