pianotuna wrote:
You might want to mention the advantage of weight. It is the only area where LiFePo4 clearly wins over SiO2.
Li banks are wonderful where it doesn't get cold, or if one is full time so the bank is in a temperature controlled area.
you also forgot size, cold weather capacity and so on. yes I said cold. at -20 degrees C SiO2 only have 60% of there capacity when fully charge, where LFP have 80 to 85% so if you take a 200AH SiO2 and you use it to get maximum lige (so they recomend a 50% depth of discharge max for maximum life) so you have a 100AH battery but due to the cold can you use all 100AH and stay with in your 50% DOD? probably more realisticaly 60 to 80AH available. a 200AH LFP you would have 160 to 170AH you can use at that temp. remember its only charging that is a no no. even then once your using the batteries they are making there own internal heat and if you have them insulated it can be enough to bring them above 0 degrees. I know mine with just a wrap around them at -6 were well above 0 degrees and thats in a uninsulated outside cabnet. when I move them inside they will be in a heated space so who cares how cold it is.
then you forget the speed of charging. if I have a 45 to 50Amp charger it has to be limited to 25amps for that SiO2, but I can pound the full 45 to 50amps into the LFP which works out to over twice the charging speed more likly 3 to 4 x as there is no taper above 80% with the LFP. and yes I charge all my batteries to 100% I don't play games and try skew numbers by staying in a spicific range an never fully charge.. GC, or LFP the aim is to be at 100% before I go to bed each day with enough reserve that I can go 5 to 10 days with out sun depending on battery type.
I do not envy the people down south that have to include AC use in there builds, that would drive the price up quite a bit.
I also don't think it is sour grapes I just think its a lack of understanding of the actual use of the LFP battery. we can read resellers websites all we want and take there word on some stuff , which is what causes have the confusion on here. I wish some of these resellers would just stop trying to put out information about LiFePO4 batteries as they are putting out half truths and in some cases outright BS and then certian people take it as gospel and spout off on the internet.
anyways I digress .....
