Lwiddis
Jan 24, 2022Navigator
Will a 200 AH Lithium battery fit? If so and understanding your power use from your post, a 100 AH Lithium will not give you the power you had from wet 200 AH batteries if you discharge only to the common 50% limit unless you fully discharge the new Lithium battery. The Lossigy 200 AH Lithium is L 19.05 W 6.69 and H 9.4 inches and currently $650.00. With the 200 you could not completely recharge it and have plenty of power.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
