theoldwizard1
Jan 24, 2022Explorer II
ewarnerusa wrote:
TL DR – I have some questions related to charging 12V LiFePo4 lithium batteries:
*How to best use my solar to charge batteries?
Any decent solar charge controller will have a setting for LiFePO4 batteries.
ewarnerusa wrote:
*Assuming I usually keep the lithium batteries at a partial SOC, what if I want occasional 100% SOC?
Not an issue, assuming you have a charger that has the proper setting.
ewarnerusa wrote:
*What about charging from my tow vehicle?
You need a DC-DC charger.
ewarnerusa wrote:it will not work well.
*What about charging with OEM converter?
Now is the time to dump that old converter and install an inverter/charger/automatic transfer switch.easy to install, easy to use.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
