wa8yxm
Jan 24, 2022Explorer III
What about charging them from Tow Vehicle. Most Vehicles use lead acid batteries these have lower charging voltages than LI types so unless you use a DC/DC converter they won't hit 100% on the tow vehicle alone.. however i'd not worry about that
What about solar.. They will (Or rather can) hit 100% with a proper solar charge controller.. by all means go 4 it....
NOTE: I'd not worry about the slightly lower charge from the tow vehicle. the nature of li batteries is it will likely be enough to get you through the overnight.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
