StirCrazy
Feb 14, 2022Moderator
3 tons wrote:
Had another good off-grid solar day today, with no meter monitoring, or intervention (100% passive)…
Stats:
200 a/hr LFP (actual load-tested at 215 a/hrs), 440w solar
Starting SOC @ 0700, 41% SOC
End of Day SOC @ 1900, 85% SOC
In approximate terms: A harvest recovery of about 44% of SOC (or 88 a/hrs) to arrive at 85% SOC…
3 tons
what was your state of charge the previouse day when the sun went down?
Im so used to oversizing my setups that if I don't see a 100% soc whent he sun goes down somthing is wrong like its overcast or the solar is broken. 99% of the time I am back up to 100% by early afternooon, in both the 5th wheel and the camper. the fith wheel I had to do this as I need that power as I only have GC batteries in there so I want to go to bed at 100% every night to make sure I have enough power as I only have 230Ah of usable power and I want to be able to survive a few cloudy days. the camper it has half that but has a 24V 235 watt split cell panel, that believe it or not out preforms the 480 watts of 12V panels I have on the 5th wheel..... the camper has no inverter so its just the furnace I am worried about when camping early spring/lait fall/eairly winter. I know I can go 3 days easy with out sun running the furnace 24/7 at 28 degree night temps and mid 30's day time.
