FWC
Apr 06, 2021Explorer
BFL13 wrote:
There are two straight lines--the constant current in Bulk at .25C in the one graph and the constant current in Bulk at .4C in the second graph. One takes four hours and the other takes one hour. How can that be?
If C is 100,
25a x 4h = 100AH and they haven't even started the Absorption stage yet.
40a x 1h = 40AH and then the 15 minute? Absorption stage gets the batt full to 100AH?
I am having some difficulty accepting that this is a sincere question, when the answer is right there in the paragraph you quoted from:
Powersonic wrote:
Stage 1 battery charging is typically done at 30%-100% (0.3C to 1.0C) current of the capacity rating of the battery. Stage 1 of
the SLA chart above takes four hours to complete. The Stage 1 of a lithium battery can take as little as one hour to complete,
making a lithium battery available for use four times faster than SLA.
You can charge their lithium batteries at 1C, which is four times fast than 0.25C for lead acid.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
