BFL13
Apr 06, 2021Explorer II
Not sure. Eg the blurb says the LFP is full when amps taper to 5% of C but you see 2-3% for FLA and 0.5a/100AH for AGMs to be full. So we need an equal stop line. Need that 1C charging profile to see how long they are both tapering and at what amps etc. to get the times right.
Some LFP advice says to charge to say 90% and not bother to charge higher, so if you made 90% the stop line in each case, that would make the SLA look better. However they like to use going to full and make restoring that last 10AH or whatever really stretch out the SLA times.
Whatever, it would be fun to see the numbers using an actual 1C LFP profile.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
