FWC
Apr 07, 2021Explorer
I guess I don't really understand your point? What is the big picture message you are trying to convey?
Yes, if you arrange the starting line and goal posts just so, and use data from a different battery chemistry it could be that lithium will charge slightly less than 4x faster than lead acid. But why is this important?
BFL13 wrote:
The Battery U link has a charge time graph (scroll down) that has what I need to make a time comparison to do a "0-90". Obviously the "90-100" times are of great interest, but I don't have that for FLA. Their graph does go to 100 on the capacity curve.
I will use my ugly graph figures without inflicting the graph on folks again, unless you all insist. I have it for a 55 amper on 220AH doing a 50-90 which is a 25% charging rate, so that makes it convenient. I just need to do it in proportion for a 100AH batt, easy! Same times at the 25% rate doing 25 amps on 100AH as 55 amps on 220AH.
The FLA Bulk ends at 72% SOC and tapers to 90%. the Batt U graph shows the time for when the capacity reaches 90% on their 100AH batt. It shows Bulk ending at 60% SOC then amps taper.
(Howls of outrage from the usual suspects!--so take that up with Batt U , not me)
So FLA first:
0-72AH at 25 amps = 2.88 hr = 173 min
72-90AH tapering = 86 min
Total time 0-90 = 259 min = 4.32 hr
Now the LFP:
0-60 at 100 amps = .6 hr = 36 min
60-90 tapering amps = 39 min
Total time 0-90 = 75 min = 1.25 hr and 4.32/1.25 = 3.46 times faster
It would look worse for the FLA if we added the 90-100 part.
What about a 40-90 though, perhaps more typical of camping?
FLA : 40-72 at 25 amps = 1.28 hr = 77 min
72-90 still 86 min
Total = 163 min = 2.72 hr
LFP: 40-60 at 100 amps = 12 min
60-90 still 39 min
Total = 51 min = .85 hr and 2.72/.85 = 3.2 times faster
So if you added the 90-100 times it would be more like the 4 times faster claim for a 0-100 looks like. (if anybody would ever do that with an FLA!)
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
