BFL13
Apr 09, 2021Explorer II
FWC wrote:
There is nothing here that is specific to lithium in any way. Unlike lead the 'operating SOC range' doesn't matter at all for lithium, you can bounce between 0% - 100%, 0% - 50%, 30 - 80%, all you need is the capacity.
Well several folks on here have said they plan to stay in mid-range. Itinerant1 has warned to stay between the knees and that he usually stays above 35%
Doesn't change anything. You pick your own SOC range and go from there.
". I have a 40Amp converter in my camper right now, but as soonn as the LFP battery gets installed that is going up to a 90 amp. can I use 90 amps right now with 210 AH of GC batteries."
Don't forget that 90 amper is not PF corrected. A 2200w can run a 75 amper, but not a 90 amper. Can you carry along a Honda 3000? I so, no problem
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
