StirCrazy
Apr 10, 2021Moderator
BFL13 wrote:FWC wrote:
There is nothing here that is specific to lithium in any way. Unlike lead the 'operating SOC range' doesn't matter at all for lithium, you can bounce between 0% - 100%, 0% - 50%, 30 - 80%, all you need is the capacity.
Well several folks on here have said they plan to stay in mid-range. Itinerant1 has warned to stay between the knees and that he usually stays above 35%
Doesn't change anything. You pick your own SOC range and go from there.
". I have a 40Amp converter in my camper right now, but as soonn as the LFP battery gets installed that is going up to a 90 amp. can I use 90 amps right now with 210 AH of GC batteries."
Don't forget that 90 amper is not PF corrected. A 2200w can run a 75 amper, but not a 90 amper. Can you carry along a Honda 3000? I so, no problem
the only section to stay away from is about 8% an less, not because its hard on the battery but your volage is dropping low and it will be harder on electronics.
Steve
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
