jaycocreek
Apr 13, 2021Explorer II
Do the LiPo4 batteries require a special charger? If so, you should include the price of that item also.
There are varying opinions on that,some say yes and others say no..The seller I bought mine from said any modern charger will work just fine and a lithium setting is a plus..Some say the Gel setting is close enough also and others the AGM..I already had a modern charger with a lithium setting..
Here is a question on just that to Expert power whom makes Lifepo4 batteries..
Question was: Can the lifepo4 be charged with a standard lead battery charger? If not Lead acid charger, then please link to what should we use?
Answer..Hello!
The charger must be LiFePO4 compatible-- we typically recommend NOCO Genius chargers.
Hope this information helps! see less
ExpertPower Direct Seller · October 15, 2019
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
