Freep
Apr 13, 2021Explorer
3 tons wrote:
... to allow for cell balancing - this is where a LiFePo4 compatible smart meter is helpful (like a Victron Smart shunt, BMV 712 or equivalent) as you can watch the voltage and current balancing act work it’s mojo...Having said that, due to LFP’s wide breadth of usable operating range, there’s really little need to fully charge a LFP except for an occasional BMS cell balancing which also allows for SOC meter re-sync.
If building your own pack I would highly recommend the overkillsolar BMS with bluetooth. This way you can easily check on the state of your battery with your smart phone or tablet. Also the Victron Smart Shunts are pretty expensive for what they do. I would recommend the AiLi current meter which is only $44 now on Amazon.
https://overkillsolar.com/
https://smile.amazon.com/AiLi-Voltmeter-Ammeter-Voltage-Motorhome/dp/B07FGFFHC6
The downside to the Aili is that it doesn't communicate with my other Victron products and it has no bluetooth capabilities, but I'm fine with that. I can see all the information about the battery from the BMS app.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
