Freep
Apr 14, 2021Explorer
3 tons wrote:
“Who was it that told me” ??...It was first hand knowledge, and be advised that I’ve mentioned this before - It was my Xantrex meter... Try as I might, once below about 60’ish %, regardless of what settings I used it would not track LFP SOC with any accuracy, nor does the owners manual specify LFP...However, the Xantrex worked flawlessly for 11 years with my former GC 6v...
3 tons
I think you may have just encountered a bad device. There's nothing I can find that shows the three devices use different techniques to arrive at the SOC. I have two AiLi meters. I realized I'd be pulling a large number of amps and would require a larger shunt so I got the bigger one and just swapped out the shunt and not the head unit because the head units looked identical. It turns out it wasn't and I was not getting consistent readings with the new shunt and the old head unit. Once I replaced the head unit too, everything was fine.
Do you think it would be more accurate if the meters counted Amp hours?
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
