3_tonsExplorer IIIApr 05, 2021LiFePo4 vs Lead Acid...Some points of interest.When evaluating the two different battery types (i.e. Lead acid vs LiFePo4), I found this ‘to the point’ summary to be both informed and helpful... https://www.power-sonic.com/blog/lithium-vs-lead-...Show More
FreepExplorerApr 14, 2021time2roll wrote:Testing an alternator vs LFP on a bench is very different than in an RV. Unless of course you have a converted bench as an RV ;)True. But if you don't use a DC-DC converter you probably should do something to avoid this.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
Related ContentLIFePO4 batteries - interesting challengesIOTA DLS-45 converter and LifePO4 batteriesLiFePO4 Converter Change?Lifepo4 float setting?LiFePO4 battery build
